raythompson
- Joined
- Nov 14, 2005
- Messages
- 108
I just picked up a Coast LED-LENSER V10 light for $40.00 from Batteries Plus. That included a case for the light. It is an impressive light. The beam is very white, as good as my HDS GT60. The brightness is also as good as the HDS. The beam pattern is not as good as the HDS.
The light runs on 3 AAAA (yes, 4A) batteries installed in a carrier. I don't know if the light is regulated or has any thermal management as I can find very little information on the light using the WEB or the search function on this board.
The light is slightly longer than the HDS and about as big in diameter. The case appears to be stainless steel but I suspect is really something else. The finish is very nicely done. The light works in an odd way. You loosen the top to have the light come on, tighten to turn off. Backwards from what one would expect.
I don't know about run times as I just recently got the light. The light does get fairly warm when using the light. It is a LUX LED of some kind, don't know if it 3 watt or 5 watt.
I like this light and may purchase a couple more of them to give to a couple of friends.
Anyone else know anything else about this light?
