I'm having a hard time understanding what is it that you want help with. Hook? Little ring? Are we talking fishing pole here? Lanyard fixed to a split-ring onto a light? If so, what light? The more specific info you provide, the easier it'll be for people to help you. That, orATVMan said:I cant get the hook to feed through that little ring anybody have any ideas on how to get it on?
Thread the split ring (the "tiny little key chain like ring") to the tip of the E2e's clip (where there's a raised part). Then clip the lobster clip onto the split ring. Or come up with your own attachment system. Here's an alternate method you could try under the clip:ATVMan said:wow i am really lost here there is a hook but theres no place to attach it to the E2e and then theres a tiny little key chain like ring on the lanyard i thought that the lobster hook was supposed to be attached to that little ring but the hook wont attach to the pocket clip
:candle:greenLED said:... Then clip the lobster clip onto the split ring.
carrot said:Now that's a good question. What the heck are you supposed to do here? Apparently Surefire wants to make you twist your brain to figure it out. I mean, with the lanyard ring on the A2/L1/L2 it's obvious... but here...
You could get another split ring and put it in the hole on the pocket clip, or you could use kite string as Porcupine did here.
About all I can think of. Maybe you should fire off an email to Surefire CS.
