NITECORE -- Keep Innovating
Results 1 to 11 of 11
Thread: I have another project idea I need suggestions for
    Default I have another project idea I need suggestions for
    Ok...I've got a wooden box cue case that I would like to make water resistant. Here's what it basically looks like (clasps are different):
    What I'd like to do is seal up the seams so that rain can't penetrate into the case and get on my cue. I think I can accomplish this by making rubber seals for it.
    Question is, should I find a way to cut a groove in the walls of the box where the two halves meet, and glue a rubber seal into each half, or should I just glue a few strips of rubber directly onto the walls where the halves meet? I think in order to cut grooves, I'll need a dremel tool and a very steady hand, both of which I don't have.
    Any suggestions?
    "I live in a constant state of organized chaos."
    Flashaholic* Arkayne's Avatar
    Nov 2005
    San Diego, CA
    Default Re: I have another project idea I need suggestions for
    I wish I knew woodworking terms.
    With the right router bit, make a channel in the middle, on the bottom half 1/8" deep and fill with silicone. Then slot the upper half and glue in a piece of plastic/wood. Think Pelican cases. Let me see if I can draw something.... best I could do with ms paint and a few mins
    edit: I forgot that you don't have a Dremel
    Quote Originally Posted by Arkayne
    I wish I knew woodworking terms. How about this:
    With the right router bit, make a channel in the middle, on the bottom half 1/8" deep and fill with silicone. Then slot the upper half and glue in a piece of plastic/wood. Think Pelican cases. Let me see if I can draw something.... (brb)
    That's the word I was looking for...lol...a CHANNEL in the middle! Plastic would be a better choice then wood for the seal...hmmmmm........
    I'm not sure though if a router wouldn't be just a little too powerful for the type of wood...it's a rather weak kind...I think they call it pressboard or something like that...I think a router would tear it up....
    Your pic isn't showing for me, Arkayne.
    Nov 2005
    San Diego, CA
    Since you don't have the Dremel, do you have an Exacto? Maybe cut a V channel on the bottom half and fill with silicone. Then Epoxy 18 gauge wire on the top half to create the seal.
    EDIT: Refresh - It should work for you now.
    The problem with using a Dremel or an exacto, is that you have to have a very steady hand and a good eye to make a straight groove. The slightest deviation from the straight line would result in an uneven seal and a leak.
    It would be sooo much easier if these were already made...hmm..maybe I can develop a prototype and send it to some companies....
    Nov 2005
    San Diego, CA
    I'm sure you could pull it off with a yardstick and a brand new xacto blade.
    You could always stick the case in huge ziplock bag until you can find a watertight cue case.
    Check out the cases at Pelican. The model 1700 might fit the bill.
    http://pelican.com/cases/3bo_1700.html
    Flashaholic* Silviron's Avatar
    Jun 2001
    New Mexico, USA
    Nevermind, Arkayne beat me to it.
    LMAO...there we go. The Super Ziploc Bag!!
    I think the case you linked to is just a little too large...they didn't even list a price for it. I could just imagine how much they want for it though.
    Oh, and I see your drawing now...that's exactly the idea I have...the design of it anyway. Just need the right materials and tools to do it without destroying the case.
    Nov 2005
    San Diego, CA
    LOL, I bet you could get a condom over both (or all 3 pieces) of your cue if you want that EXTRA protection.
    edit: in the rain that is.
    LMAO!! I could imagine the look on my opponent's face when I pull out my cue! "And what exactly are planning to do with THAT?"
    hehehe
