RebelXTNC
The caps from Deer Park brand .5 liter water bottles have an inner seal ring that is a perfect fit for Fenix L1P and L2P lights. The whole cap is too large, but that inner seal is a press fit and the cap will stay on pretty snugly. These caps are transluscent and make a good flood converter that is low cost, disposable and easily replaced. You could trim these caps down, but the outer body portion basically gives a small amount of light out to about 150-degrees if you're viewing the pattern from the side.
I've been testing white and transluscent bottle caps of various brands and these were the first I've found that were actually snug.
I haven't done a heat-up test to see how they fit after 20 minutes or so. Maybe I'll do that tonight after dark... at least it worked well in the typical "bathroom with door closed test" this morning.
