I think bezaur method is right on the money, no need to try ebay, just go to Wal Mart electronics department and ask for some, they have penty from the stuff they unpack they should give it to you for free, stuff as many as you can into the body and leave it in the sun for a while.
What is being described above is not a vacuum desiccator, but may work. It involves getting little bags of desiccant (usually silica or alumina). These bags absorb moisture, so if you get them and put them in the body of the light and then put the light in a warm spot (oven or in the sun) then the desiccant will slow pull the water out of the head.
The vacuum desiccator suggestion is also a great one, but you need both the desiccator and a vacuum pump - the latter which is not readily available in homes. If you know someone who works in a chemistry lab or other type of lab, they may be able to help you. This may require some care if the head is water tight- pulling a vacuum on something which is sealed could result in an unexpected result...like the o ring blowing.
Sam
