Wuben
Results 1 to 17 of 17
Thread: LED Data from "Light Box" ...
    Jan 2005
    Texas, USA, Earth
    Default LED Data from "Light Box" ...
    My Light Box was designed primarily to test LED's. Here is my first set of data.
    As we expected, the "S" bin 1Watt and "U" bin 3Watt do excellent in terms of lumens/brightness or LBU (Light Box Units, since it is not calibrated to any known value). When you take into account the power going to each LED to produce the light intensity, it gets pretty interesting in terms of efficiency
    In the graph below, efficiency is directly proportional to the intensity divided by the power to the LED, times a scaling factor. As you can see, the "W" bin 5Watter makes the most light, but it take a LOT of power to get it
    The "ID" is just that - an ID to uniquely identify each LED on the back of the star. Power to the LED is in Watts (simply vf times 0.750).
    I still have quite a bit of LED's to test, but so far that UW0K looks mighty nice
    Will
    Please no PM/Visitor Msg's. Email for questions/Paypal: wquiles [at] gmail {dot} com
    Jan 2005
    Texas, USA, Earth
    Default Re: LED Data from "Light Box" ...
    reserved
    Aug 2004
    Sydney, Australia
    wquiles
    Thanks for getting more data out there- your birdcage light box (BirdyBox??) is going to help people make sensible decisions.........
    Kind Regards
    David
    Jan 2005
    Texas, USA, Earth
    Thanks David. It will get more interesting as I add more LED's over the next couple of weeks
    Will
    Jan 2005
    Texas, USA, Earth
    I tested additonal LED's tonight. The new data are the four WX1S 5-Watters shown last on the table.
    To re-check the setup, I tested again an LED from the first session, LED 3-1 (SYAJ). Last time I got a vf=3.39 and LBU (Light Box Units = intensity)=280. Two weeks later, I test the same LED, same everything, and I got vf=3.4 and LBU=281. I don't know about you, but this is (so far) pretty amazing repeatability !!!
    Here is the updated data:
    Will
    Thumbs up Re: LED Data from "Light Box" ...
    How about getting an X-binned emitter in "The
    Birdhouse" ?
    Cheers !
    Jan 2005
    Texas, USA, Earth
    That would be awesome!
    Right now I have very repeatable data, but nothing to "calibrate" my readings against - hopefully soon
    Will
    Did you get a chance to obtain some more U-bin emitters ? (maybe J for voltage-bin?)
    Jan 2005
    Texas, USA, Earth
    Yes, I tested a "J" voltage "U" bin 3W in here .
    Tonight I also tested additional "U" bins here
    Will
    I'd like to see how some S-bin 1W perform head to head against a U-bin 3W at 500ma. Especially some of the recent S_0H LuxI's versus Fred's UX1Js luxIII's.
    ( I need data for some upcoming mods )
    -DF
    KineticParadox ...a personal web space with my CBA Battery Testing and my LED Bin Coding Charts.
    Jan 2005
    Texas, USA, Earth
    Quote Originally Posted by DFiorentino
    -DF
    I already have tested several "S" 1W LED's against "U" 3W bins as shown above, but you are right, not yet at 500mA - so far, the 3W "U" bins are marginally more efficient when driven at the same current level.
    When I started I used a DB750 and it was not until recently that I created the second module with a DB500, so I don't have lots of data with it yet. I am now thinking that a DB 250 would be perfect since at those levels LED's are even more efficient, specially something like the newer "W__S" 5W LED's available recently
    Will
    Yeah, I was just pondering what to install in the PD...
    Wiz2x2 @520ma UX1J vs. Wiz2x2 @520ma S_0H
    Probably a close draw lumen/efficiency-wise, but I'd be interested to see how tint plays out at the under/over-drive currents.
    -DF
    Jan 2005
    Texas, USA, Earth
    From what I have tested so far, the U bin 3Ws are a "little" brighter than the S bin 1W. Your milleage might vary
    Will
    Dec 2004
    Oklahoma
    Quote Originally Posted by wquiles
    Will
    I just replaced a TXOJ Lux3 with a SWOH Lux1 in a Nexgen 280 light engine. Got a 45% increase in lux readings. Either the TXOJ was at the low end of its bin, or the SWOH was at the high end.
    Jan 2005
    Texas, USA, Earth
    Quote Originally Posted by wasBlinded
    Based on the "S" 1W, "T" 3W, and "U" 3W LEDs that I have tested so far, this is exactly that I expected to see. All "S" 1W bins that I have tested have been at almost the same intensity as "U" 3W bins, so you are "seeing" the same thing I "see"
    Will
    Hey Wquiles, you do realize that you've got a UWOK binned emitter labeled with VF as 3.49? Apparently it's the superstar in the chart. Maybe some numbers should be double checked. I mean, doesn't 3.49 make it a misbinned UWOJ (and it should be a little lower at 700ma, right)?
    Titanium flashlights are like solid gold radial tires
