KevinL
First of all, credit must certainly go to rapt for his original thread which gave me the ideas. He was kind enough to share his sources for the material as well.
In turn I thought I would also give some back in the form of what I discovered.
I got my kit, really quickly - the ebay seller is a real fast shipper. :thumbsup:
Seems to be made of good quality materials, I am surprised, especially for the price. Usually, the auto stores prefer to sell you the $500 way overpriced kits. Of course, this kit has no transport authority approval, but as I said, that isn't a concern for spotlights propelled by two feet
More details when I start building the lights.
In the meantime, I placed the HIDs into one of my spotlight reflectors (in line with my policy of *NEVER* lighting any hotwire bulb without a protective housing because of the detonation risk) and tried test-firing it with a 12V SLA battery. The ten-amp inrush current causes a whole lot of sparks when I touched the leads to the battery terminal, talk about scary... yes, it is rated for 10A strike current, so your batt packs had better able to take it.
Sustained current draw of the HID is around 3 amps. Operates from 9-16V (automotive voltage). Construction really does appear to be quite well made, full metal housing around the ballast, weather sealing around some of the connectors although I would still avoid getting it wet.
And damn that HID is BLOODY BRIGHT - I ordered the 6000K bulbs (vs 8000K or 10000K). The higher the color temp (CCT), the bluer the light looks. Lots of the rice racers on the roads love to get the super blue, super-annoying kind.. I got 6000K because it is closest to daylight and it actually puts out MORE light, because the halide mix to get blue light does impact the amount of light that comes out of it.
It is awesome.. seriously white, we're talking Luxeon LED white, and you know me - sensitive enough to tell the difference between Luxeon tints just by looking at them. Even my Mag2HID is bluer than these.. I like. At first I was worried that the cheap China HID wouldn't be bright, but it sure is. I can't wait to build it into the production spotlight, then try it outdoors in Quality Dark. From the light output I'm seeing it is already CRAZY BRIGHT.
As is typical for automotive HIDs, the HID starts up very bright when you first hit the power switch then goes to brightest after a few seconds. Smaller HIDs start extremely dim (Mag2HID), then warm up to full power. Auto/car HIDs strike at a reasonable brightness level, then go to full power.
I am impressed.. the quality of the stuff coming out from the Far East has improved greatly in the last few years. This HID kit seems decently well built and its performance is certainly up to par.
