Sold/Expired WTB: Lux I side emitter star
perfectname
Bainbridge Island, WA
I'm looking for a Lux I side emitter star with a good tint. I would prefer R bin, but if nobody has one I'll take a Q. Does anyone have one they could part with?
perfectname
I looked there but it looks like all the white ones are either high-dome or batwing. The light I'm working on (UK eLED) uses a side emitter, and I don't think anything else will work with the shallow reflector.
Christoph
Hagerstown,Md
I have a few se's when I get home this afternoon I will check.they might be Q or P-X1J's.If I have them you are welcome to them.
Chris
perfectname
Thanks Chris. I would be interested in the Q if you have it. I guess even a P would be better than the NX1K I'm replacing. I'll look forward to hearing what you have.
Nathan
cratz2
Central IN
Wow... some of the eLEDs had N-bins in them? That's awful. I recently bought one and the tint is very nice... slightly green-ish yellow, but only very slightly. I was all set to upgrade it, but to be honest, I like the tint so much, I'll probably just stick with it unless I can find a really nice T**H Lux III side emitter.
Since the board seems to be constant current, you could use a Lux III and the output and runtime would be about the same as the equilavent... ie, a Lux III T-bin would be the same as a Lux I R-bin.
perfectname
Yes, the NX1K was truly awful. It always seemed like it should be brighter. One night I got so frustrated I ripped off the reflector and was pleasantly surprised to find that I could whittle away the epoxy around the star.
I think you are right about it being constant current. I put a 10 Ohm resistor in series with the LED. The brightness was almost the same and the voltage on the LED was only .02V different.
cratz2
Central IN
I know Photon Fanatic had some S-bin Lux III side emitters last time I checked his 'main' thread... Pretty cheap too, I think.
