leukos said:Probably a SF G2 or Pelican M6 will be your most bang for the buck with throw.
TinderBox (UK) said:
DoubleDutch said:Not 2x123, but closest in skinnyness:
http://fenix-store.com/product_info.php?products_id=32&osCsid=4234c4810b30112db2d0d6650d46a848
Kees
Double_A said:I doubt if your going to find what your asking for.
Most 123 based lights are one inch in diameter.
My Fire~Fly single 123 Light is 0.80 in diameter. It is the slimmest 123 light I've seen. It has very thin walls as the 123 cell is approx .65 inches in diameter.
Now if your interested my Fenix L2P is 0.80 inches in Diameter and takes two AA cells and is 5.6 inches long.
Another option is a modified Mini-mag body (0.715) with an LED
Double_A said:E2e may be your ticket mine is 0.75 across the flats and 0.81 across the round sides.
nuggett said:check the Vital Gear bodies
metalhed said:One other idea I haven't seen posted.
The Streamlight Scorpion might do the trick if you cut away some of the protective rubber covering. I don't have calipers, but a tape measure eyeball makes me think it might come close. Looks like it might make the .80 requirement...maybe.
Kryosphinx said:You can email lighthound.com
He's really helpful
shotgun said:Could someone recommend an inexpensive flashlight with a .75 inch body diameter? What's your best skinny 2x123 flashlight? LED or incandescent is ok but throw preferred.
