Rustam Bana
Hello everyone.
It's my first post on CPF and I hope you would be able to suggest a flashlight having the following parameters.
1) 3 or 5 watt LED.
2) Regulated power.
3) Powered by no more than two CR 123A cells.
4) Minimum of 30 lumens.
5) 2 hours minimum runtime at full brightness.
6) Need a flawless white beam with the bias towards throw rather than flood.
7) Needs to illuminate objects 100 yards away if not more.
8) Should be robust and waterproof/water resistant.
9) For use primarily in forests and brush.
10) Dimmer optional.
11) Would prefer to stay within $100.00
12) I prefer a 'clicky' to a 'twisty'.
I would also be grateful if you could recommend a Luxeon type LED for a 2AA Maglite, 2D Maglite and 6D Maglite or would you recommend that I wait until Maglite introduces it's LED series.
Thanks and best wishes.
Rustam
P.S.: I would also be grateful if you would recommend a few good retailers for the above.
1) 3 or 5 watt LED.
2) Regulated power.
Rustam
