Nitrile/Buna-N(O Rings) vs Petroleum Jelly(Vaseline)?
Navck
Southern California
Well I found out that my silicone lubrcant in a can contains acetone, and that stuff will pretty much melt O-Rings, anyone had experance with "white petroleum jelly" with Nitrile O-Rings?
scott.cr
Los Angeles, Calif.
Re: Nitrile/Buna-A(O Rings) vs Petroleum Jelly(Vaseline)?
BUNA-N is listed as "highly resistant" to petroleum products, not including solvents.
Sub_Umbra
la bonne vie en Amérique
Navck said:
Well I found out that my silicone lubrcant in a can contains acetone, and that stuff will pretty much melt O-Rings...
What's the brand name? Does it list acetone on the label or did you find out some other way?
Navck
Southern California
Pyroil is the brand name (Subsidary of Valvoline)
Its listed as a multi-purpose silicone lubricant
Contains - Heptane (142-82-5), Acetone (67-64-1), Polydimethylsiloxane (63148-62-9), Carbon Dioxide (124-38-9)
Can I use WD-40 as well, or does it contain some nasty universal synthetic rubber killing chemical?
changsn
Palo Alto
Agree with SubUmbra - nitrile is good with heptane (petroleum based products). Usually the EPDM is what is killed by petroleum based lubricants (like WD-40). My EPDM Oring on the Nuwai died quickly under these conditions.
Sam
chmsam
3rd Stone
When in doubt, always good to look for a Materials Safety Data Sheet (MSDS) for a product. It will give safe handling, use, and storage info. plus a listing of the components/ingedients.
TedTheLed
Ventura, CA.
bh, you work for Aloha Airlines by any chance? :ironic:
%100 silicone is available, and Inova recommends it, so I use it.
..um..what do you chemist types think about 'Superlube' (the brand name) ?
changsn
Palo Alto
Not to hijack the thread, but the question on Superlube is not really a chemical question. I think you are asking whether it works well and that is an application where someone would need to test. If you are asking if Superlube is compatible with nitrile/BunaN, then the ingredients would need to be determined. If the ingredients are petroleum based, it should be fine with BunaN.
Sam
TedTheLed
Ventura, CA.
exhaustive ingredients listings of materials here:
http://hazard.com/msds/mf/perm/files/20029.TXT
n-HEPTANE 142-82-5 60-65
Synthetic hydrocarbon,
poly(alpha-olefin) based 68649-12-7 30-35
CARBON DIOXIDE 124-38-9 3-5
Modified silicon dioxide 68611-44-9 3-5
Poly(tetrafluoroethylene) 9002-84-0 1-3
Ingredients which have exposure limits
Exposure Limits (TWA) ACGIH OSHA OTHER
Ingredients (TLV) (PEL)
n-HEPTANE 400 ppm TWA 500 ppm TWA None
1640 mg/M3 1600 mg/M3
poly(alpha-olefin) based 5 mg/m3 mist 5 mg/m3 mist None
CARBON DIOXIDE 5,000 ppm TWA 10,000 ppm TWA None
9,000 mg/M3 18,000 mg/M3
Modified silicon dioxide 10 mg/m3 6 mg/m3 6 mg/m3
Exposure Limits (STEL) ACGIH OSHA
n-HEPTANE 500 ppm 500 ppm
2050 mg/M3 2000 mg/M3
poly(alpha-olefin) based 10 mg/m3 None
CARBON DIOXIDE 30,000 ppm 30,000 ppm
54,000 mg/M3 54,000 mg/M3
