Buster Bodine
- Joined
- Mar 8, 2006
- Messages
- 87
Hello!
I've been lurking here for a month or so, hoping in that time I'd eventually figure out what all of you were talking about and I've decided to give up! Most of the tech stuff you're saying leaves me completely confused but thats okay. I don't mind being one of the "special children." To tell you a little about myself, I've got a few "good" flashlights and would like to have more. I have four, five, I don't know, maybe six Maglites of different sizes, an Inova X5, a new model X1, and an old, slightly battered but still very usable Surefire 6Z. So yes, I do appreciate good lights but I'm certainly no "techy" with them (Perhaps that will change here.)
I do have a question though, it may even develop into a series of questions before its over, so please bear with me and please realize, if you start laying tech talk on me, I'm lost before we start.
Concerning the Inova X1
I've noticed the general consensus here seems to be that the X1 is a better light in a "flood" configuration than in a "Spot." (Correct me if I've got the wrong impression) First, why is that? I've always prefered a tight, relatively bright spot.
Toward that end, I discovered that placing a small 10x magnifying lens in front of the flat glass lens of the X1 narrows the entire beam by approx 50% and also visibly brightens the "hot spot" in the middle. I've also noticed that moving this 10x lens further forward in relation to the bulb dramatically decreases the width of the beam and creates a hot spot so well defined, the elements of the LED actually cast a sharply defined shadow on the wall.
I haven't seen anything that says one way or the other, as a newby basic member, do I have pic posting priviledges? If so, I can post some beamshots to show what I'm talking about.
Anyway, the biggy question of the post is this. Would it be practical to have an "almost" correct size 10x lens cut down to the proper dimensions to replace the flat one?
If so, do you think the result would be desirable or am I woofing up the wrong tree?
Is there an easier way to accomplish what I want to do? (Create a tighter/brigher spot in my X1)
Thanks, I'll now sit back and hope one of you MIT/JPL type flashlight scientists have all the answers and can put them in terms a poor old layman can understand.
