KDOG3
I'm considering the 5W head from BOG and I have a few questions. First of all, what do you think of it? Will it work on 9V bodies? Does the LED base screw into the reflector like the 3W? Thanks for any info!
wquiles said:I have swaped the reflectors between the 5W and the 3W (since they are both the screw-type) so you can fit the 5W module anywhere the 3W fits. Yes, the beam is different, but it allowes you to play with different focus as you can also play with the different o-rings (different on both of my units).
Like cy, my 5Watter came with a fairly nice and white tint LED
Will
YesKDOG3 said:Wait, you can put the 5W module in the 3W reflector? Does that mean it will then fit in a stock bezel?
