My SRTH recently developed a void in the beam that was not there before. It was always perfect, with a bright central spot, and even spill. Now my spill is not so even.
I called SF, and the guy I got told me that "the bulb causes that, not the reflector", and suggested that I rotate the bulb. Having already had the bulb out several times, and tried my spare that also had a perfect beam previously, this was not the problem, but I tried it several times anyway.
Guess I'll call them back, and see about sending in the SRTH, but I wanted to see if anyone else had had this happen to them.
Hard to tell from the pics, 'cause of the way the camera adjusted to the light, but the "void" is not symmetrical.
btw, my walls are a beige color so the beams may look off-color a bit in the second two pics. The first shot is on a white door. The LA is the N2. Pics are untouched. Because of the close range, I used the "museum" setting so the brightness wouldn't white out the camera.
