Robocop
Moderator, *Mammoth Killer*
Ok I searched several old threads and have became very confused as to the current 12 volt set ups available and never really found an answer as to the ability to run protected 123 rechargeables with any 12 volt lamp assemblies.
Some say it did work and others say it did not. G&Ps stuff looks promising however some said their lamps were different and did not work while others had success.
Ok to sum it up I have had so much fun with my new 9 volt D36 I am really wanting to try the new 12 volt D36. I assume the reflector is 36mm and it seems to be the same general size as the 9 volt D36. On their website it says it will only fit the M90X and not the Raider that I have. Has anyone actually handled the 12 volt D36 and even more curious has anyone tried to fit one in a 9D Raider body with rechargeable 123 cells ?
I also remember reading several old threads that warned about using more than one non protected Li-Ion cell for danger of a dead short or something about venting and flame.....sounds bad to me but is this still an issue with the advance of the newer cells?
