beondwacko
- Joined
- Mar 28, 2006
- Messages
- 6
Hello Folks.
I'm fishing for a few ideas for landscape lighting applications with LED's. THe main reason why I'm posting this request is because I just recieved an order of 10mm 130K MCD white LED's and I'm bigtime disappointed with the output of these units.
They are rated to have a 12 degree beam spread +/- 5 degrees. Yeah, I'd say 7 degree is about right. They throw a tight narrow spot with very little spill over, and at a distance of 4-6 feet or so, I get the intensity that I was looking for. The "brightness" at a distance of about 1.5 feet or so against a white wall was nowhere near 13X of a 10K MCD with a 20 degree spread.
I was planning on using the 10MM for uplighting purposes on palm trees, mounted in a copper tube, about 12-15 feet below the area of desired illumination. I wanted to keep this set-up simple and unobtrusive apon install. The copper tube would only extend about 5 inches above ground level, and would patina over time and blend in with the other natural earth tone colors over time.
I ended up ordering another 50 pcs of a 5MM 40KMCD 20 degree LED's last night. I'm trying to avoid building a matrix if I can help it just for astetics, and reduced build time and complexity. I also like the idea of using non-luxeon types of LED's just for the reason of reduced current draw and cost. I'd like to be able to keep the copper tube idea of mounting the LED's, but I'm thinking that I'm going to have to group mutiple (4) LED's together ( in series ) to achieve the desired effect. I may have to build a "bullhorn" style of framework(think of the letter T , with the top bar drilled out to mount the led's) but that's gonna' be tough to fish the wire through, and very conspicious).
SO here I am, fishing for ideas on types of LED's to use, and also to see what else has been done before just for inspirational reasons. Post away people. I'm curious to see and hear what the more experienced crowd has come up with.
Thanks in advance.
Thanks in advance.
