Run time of a 9p...
Timson
Leeds - England
Depends on the capacity of your Li-Ions.......I'm guessing about 1100Mah...
Should put it roughly in the 50 minute ballpark - give or take a few.
Are you running P90?
You'd get more runtime and more output with a G90
Tim.
RowdyOne
Connecticut
They are 1100mAh and right now the P90 is in. I do have the 9v Digilight lamps. How much more run time and output would that get me?
Thanks again!
Timson
Leeds - England
If its the more efficient G90HP....I believe it draws about 850Ma.
So that works out at about 78 minutes (assuming that you can get the full 1100Mah capacity at that current draw)
Count on a full hour of good bright light...Then re-charge.
Output wise :
P90 - 105 Lu
G90HP - 175Lu
Tim.
RowdyOne
Connecticut
Sorry, i should have mentioned that these are not the efficient ones. They run @ 1.15-1.2. i ordered direct from Digilight to try in a 6p with R123's. I am on the backorder list for the "good" ones.
Timson
Leeds - England
In that case your G90 should be comparable in output and runtime to the P90.
Differences will be in beam characteristics.
Tim.
