perfectname
I'm not sure how interested people will be interested in this, but here it is anyway.
I've owned a couple of these eLEDs. I couldn't figure out how to take the first one apart non-destructively so I ended up cutting it apart with a saw, and salvaging the circuit from it. But I really liked the form factor and regulation so I bought a new one.
The new one was kind of dim and had an ugly tint so I didn't use it much. One evening while messing around with it I found that I could pop the reflector off the eLED module. After that I was able to gently whittle away the epoxy from around the star with a knife and finally free it. It turns out the LED was an NX1K. Christoph was kind enough to give me another side emitter star (a PV1K) which I have now installed. Right now the star is held down by bits of hot glue, and the reflector is just loose. I am going to wait until I can find an R bin before I use a stronger more permanent glue.
I measured the current through the LED at about 196 mA. What's interesting is that my other, older circuit drives the same LED at only 127mA so I'm wondering if maybe UK changed it at some point.
