Actually, ZWF, if you are referring to Gessner's WY0S stars, check the thread awhile back. The last batch measured R-bin Vf, a record setting efficiency high with the lowest Vf numbers seen for a Lux V! Cy measured something sick like 5.95V or so driven at spec, made me drool and order some for myself. We shall see if this batch is the same. Any case, you are good to go with the Shark, its what it was designed for. I had the same thought as you, got a PTS D from Shoppe, a Mag host (in HAIII from WTRaymond), Gessner's trio of awesome Lux Vs.... all I need is the right converter and power solution and I'm good to go too! Good luck! Oh, check out Flex76Italy's 15W Cyan monster mod. Lucky and clever fellow got George to make him a hopped up nFlex that can drive three Lux Vs.... (cyan eyed with envy over that one!)
