Klarus
Page 1 of 2 12 LastLast
Results 1 to 30 of 48
Thread: Adjustable ArcAAA TX0H miniFLuPIC (pics!!)
    Flashaholic* chimo's Avatar
    Sep 2004
    Ottawa, Canada
    Default Adjustable ArcAAA TX0H miniFLuPIC (pics!!)
    Here is another ArcAAA mod. The driver is a mini-FLuPIC by goldserve. It is similar to his other FLuPIC drivers, with the exception of it having one, rather than two, LDO regulators. The board has been sanded down a bit around the edges to allow it to fit in the Arc head.
    Driver Topology: A low drop out (LDO) regulator limits the maximum output current to around 500mA. The LDO regulator is PWM enabled by a microcontroller.
    There are three output levels. Two levels are selectable from 5-100% in 5% increments (20 levels) and the third is full on. This driver also also has Strobe and SOS. There are 5 menu modes - normally, you choose a mode and leave it there (I prefer mode 4).
    Click on the pics for a larger version.
    Here is the FLuPIC Mode guide. (My favourite is Mode 4)
    Old pill and new driver board. The board needs about 0.5mm removed from the diameter to fit snugly.
    A test fit of the miniFLuPIC after edge sanding.
    Here it is being tested (Low and medium).
    Head - before and after bevel of first ridge inside the lip.
    Why the bevel? Clearance is very tight in a few areas and the bevel will help avoid edge pins. On the final build I put a thin coat of epoxy on the affected pins for electrical insulation.
    Reshaped (more parabolic) and polished head. Should I moisturize?
    Most of the parts. TX0H LuxIII or SV1J LuxI (on the way)?
    I was very impatient today and did not wait for the SV1J so I used a TX0H instead.
    BUILD COMPLETE
    Heatsink Fabrication. I decided to make the heatsink thicker so I made it out of two copper layers soldered together (flattened solid copper penney).
    Board Ground Tab
    It fits snugly. What if you need to remove it? Installable pull-tabs.
    Assembled Head
    Beam Shots compared to ArcAAA w/ new NichiaCS (Arc on the Left) Low/Med/Hi (10%/40%?/100%). (Note: The colour balance on the camera must have auto adjusted on the brightest light - Arc in the first photo and on the mod light for the other two.)
    Run-Time Test High (100%) and Medium (50%). I had a fan blowing on the light for the 100% test but not the 50% test. I ran out of time to do a 10% test, but I plan on running one. I expect about 5+ hours for the 10% test. I have mine set at 10% - great for night nav around the house. The behavior at the end of the curves (the rise in output) are typical for this type of LDO regulator and consistant with my previous tests.
    I added a 10% run to this graph. I ended the test after 8 hours (it was late, I was sleepy, I had to go to work in the morning and I didn't want to run the risk of over-discharging the Li-ion). I checked the no load voltage on the Li-ion after the 8 hours and it read 3.79xxV (I forget what the xx was - didn't write it down). I believe 3.8V corresponds to around 30% of battery life remaining.
    Thanks for lookin'
    Paul
    Dec 2004
    Toronto, Canada
    Default Re: Adjustable ArcAAA miniFLuPIC WIP (pics!!)
    Just a point to note, the two critical points on the IC are okay to touch ground. =D
    That is a very cool mod!
    Sep 2004
    Ottawa, Canada
    Thanks, I edited the picture but imageshack is doing some wonky stuff and will not give me my thumbnail links.
    Paul
    Edit: got it fixed.
    Jan 2006
    Bartholomew County IN
    Is that for sale?
    I want take it .
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    LOL @ moisturize. My hands look like that in winter. I get vertical splits in my fingertips actually! I hate hand lotion though (or anything on my hands stick/greasy), so I suffer.
    Flashaholic* jar3ds's Avatar
    Sep 2005
    USA
    dang... looks yummy! Is the waterproof-ness lost @ all with the Luxeon?
    I've been looking for a li-ion option for my ARC AAA because thats my fav. battery chem. and ya just got'a love the flupic
    I do feel that you will get a lot of orders if you sell these... I'm in for one....
    Dec 2004
    Toronto, Canada
    chimo,
    free FLuPIC board = you have to make me one too
    Flashaholic* DUQ's Avatar
    Jun 2005
    Ottawa, Ontario, Canada
    Nice work chimo. Talk about small eh. Glad to see one of us getting there mod off the paper.
    LED's impress but Incans satisfy
    Oct 2004
    Hong Kong
    Thumbs up Re: Adjustable ArcAAA miniFLuPIC WIP (pics!!)
    Nice job, chimo
    I have 3 of those AAA heads with Lux I RWOH for about a year now. The chips were assembled together by 3D soldering. These are gems ! I have one on my keychain, one with a N cell body and one with a bass double-headed tube. The UI is low/high/strobe/sos/brightness adj
    Feb 2006
    Tucson, AZ
    Well, that looks like a good use for AW's 10280 sized (2/3AAA) Li-Ion. Is that a Jets22 N-sized tube for the Arc AAA head that is shown in AW's picture alongside the 10280 Li-Ion? I've been wondering if it could produce enough current to run a Luxeon in a cut-down Arc AAA body. Of course, now I'll be wondering if that tiny battery can power a Lux-III, or if a Lux-I is pretty much the limit.
    This mod looks like it is going to create something even smaller than the JIL Intelli, with all the same features. Good work.
    Nov 2004
    Virginia
    I would love to see a beamshot comparison between the TWOH and the SV1J.
    Flashaholic* mosport's Avatar
    Sep 2005
    Toronto, Canada
    Looking good Chimo, nice pictures too!
    Your mods are always clean and tight, any tips on reshaping the reflector and enlarging the head's inside diameter?
    Can't wait to see the rest of the build pics...
    Sep 2004
    Ottawa, Canada
    Thanks for the kind words. This is still a WIP (work in progress). I have not decided on the emitter yet - the S-bin LuxI has not arrived yet so I will have to wait until after the long weekend.
    Isaac, same problem and same dislike for greasy lotions.
    inq2000, sorry this one's not for sale.
    jar3ds, it would be fairly easy to make this water resistant. There's lots of room inside.
    goldserve, PM sent.
    AW, very nice. Is that the POP version?
    Grumpy, if I get impatient and put the TX0H in there this weekend, I have another TX0H to compare beamshots.
    mosport, I put the head in my drill press. I then used a dremel tool with a spherical metal bit (will try to post a pic later) and free-handed it. I followed up with some varying sandpaper and brasso.
    EDIT: pic posted above
    Paul
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    Quote Originally Posted by chimo
    I'd be very interested in a pic of that Dremel bit.
    Quote Originally Posted by goldserve
    Exactly what two critical points are we talking about here?
    Sep 2004
    Ottawa, Canada
    Quote Originally Posted by greenLED
    I must have been posting the pic while you were posting. I find that the stonetype clog with Al too easily. If I use the stone bits, I clean them with a wire wheel on a normal drill. The metal bits cut very well. See first post.
    I posted a new pic with the critical points. I had the outer two on the uPIC listed in my initial post. The areas of concern are LED+, the cap, and one leg of the LDO.
    Paul
    Mar 2004
    La Tiquicia
    Yes, you were! You're always very helpful, chimo, thank you very much for sharing. Wow, that drill bit is really small.
    I should get off my lazy butt over the weekend and make a list of supplies I "need".
    Sep 2004
    Ottawa, Canada
    Default Re: Adjustable ArcAAA miniFLuPIC (pics!!)
    Finished this off today.
    The first post of the thread has been updated with a bunch of new pics.
    Looks like I found a new keychain light! I still have to do some run-time tests, but I am very pleased with the results.
    Paul
    Mar 2004
    La Tiquicia
    Awesome mod!! Thanks for all the extra pics. Are you using a penny as source for the 2-layered micro heatsink?
    Source for AAA li-ions?
    Any chance of protected AAA li-ions?
    Sep 2004
    Ottawa, Canada
    It's an old penney. It met Mr Hammer prior to those pics. Hammering down the ridges helps speed up the smoothing process.
    I believe I got the AAA Li-ions from AW or Emillion. It would be hard to shrink the protection circuit in the area of a AAA.
    Cheers,
    Paul
    Mar 2004
    La Tiquicia
    Even armed with sandpaper, last time greenLED met penny, he lost his fingertips. I'd rather not repeat the experience. uch:
    Mr Hammer! I shall use such a fine-tuned precision intrument with great care (as to not destroy it's delicately tuned functioning).
    Thank you so much, chimo!
    *Flashaholic* andrewwynn's Avatar
    Apr 2004
    Racine, WI USA
    great mod.. holy cow on the heat-sink.. wish i'd have known i make them in about 3 seconds now.. i use a pneumatic punch to make the 8mm circle (usually out of silver) and take a 'nibbler' to notch out the two emitter holes. Did you learn the 'hard way' about the shorting of the pins.. i shorted out a LOT of lights in the process of learning how to make a nano.
    I thought i saw some question about prot. ckt.. pretty much unnecessary with AAA size LiON. i've dead-shorted them many times.. they just get very warm.. the specs on the first batch i got included being able to deal with dead shorts..
    Probably unnecessary to double-layer that heatsink.. i use about .8 or 1.0 mm thick copper or silver... the key is to use some thermal compound to get the heat out of the sink into the head.
    looking through the pictures gave me some serious nano flashbacks.. and i still have paylenty more to go.. fortunately with good help things are finally getting cooking.
    -awr
    Regulated hotwire 'the hotdriver' also for Surefire M6 • 3-level high-power LED drop-in for mag. the 'BAM!' click here
    I have disabled PMs.. use the 'email' link instead!Genesis 1:3 And God said, "Let there be light," and there was light...
    Sep 2004
    Ottawa, Canada
    Quote Originally Posted by andrewwynn
    -awr
    I could have done the punch thing at work (but I was off today). This certainly took longer. I used a file for the notches (brazenly stolen off the nano, btw ). I did have to correct an initial short - AA epoxy cured that problem (no pun intended).
    Paul
    Dec 2004
    Toronto, Canada
    Whoa, nice to come back from a short vacation to see the final product! cheers! Great work!
    Apr 2004
    Racine, WI USA
    Paul
    Glad to see the influence like that.. i actually had over 100 solid copper 99.999% pure heat sinks i made at the cost of about $400 that turned out to be too thick for the final design.. part of why nanos cost me money to make... but at least i am making enough so it's not that much per nano.
    -awr
    Sep 2004
    Ottawa, Canada
    Thanks, Kevin. (btw, notice that I made 2 heatsinks).
    Andrew, Lots of room in this one. I put a 3mm spacer block (between the board and the heatsink) to give the board more support.
    Paul
    Sep 2004
    Ottawa, Canada
    Default Re: Adjustable ArcAAA TX0H miniFLuPIC (pics!!)
    I have decided to do a very limited (<10) run of these.
    I will start a new thread in the Custom B/S/T for this in the next couple of days.
    Cheers,
    Paul
    Sweet! Can you give an estimate as to how much they will cost?
    Sep 2004
    Ottawa, Canada
    Quote Originally Posted by adirondackdestroyer
    I have not got all the parts ordered yet but they should be around $100 (likely less) and will include a lug body.
