10mmWiseman
Does anyone have any feedback on this light? I am curious to see some beamshots and where abouts the lumen rating actually is. I understand the 120 claim is a little farfetched.
FirstDsent said:DO NOT FIRE YOUR PISTOL 66 FEET UNDER WATER! -BAD, BAD! Bernie
Nope, whole different lamp setup. My terminology is still weak here, but I will try. It is like a bi-pin (like a Stinger bulb), set in a plastic cradle with a spring to absorb recoil around it. Surefire makes a handgun weaponlight, I believe called the P101 or something light that, that takes P60/61 bulbs, but it is big and bulky. If this light didn't have to go into a holster, I would imagine you could do the old 2 rechargeable 123's and a 9v lamp and have something very bright.Maybe someone can tell us if the SureFire P-61 module will fit.
The water basically would act as a barrel obstruction. The bullet would have no where to go. Going by an episode of Mythbusters and some other info, chances are the person firing the gun would be OK, but you could do severe physical damage to the gun, barrel damage, locking block, etc.OK, I'm ignorant. What would happen?
Northern Lights said:Hey, can anyone tell me what that enlightened and unenlighten by the user name and avatar means? Been driving me nuts, I probably overlooked the obvious.
