Well, the deal went through. I am the owner of a basic 1996 e250 ford van. inline 6 engine, 80 amp alternator and NO AC.
With this muscular disease having AC really helps to catch the second wind and keep going. When I crapped out of a day I just sit in my chair with the ac cranked and a fan blowing in my face. After an hour I am ready to go again.
Anyway, looking at how to cool myself and part of the van. THe aftermarket ac kit from jcwhitney is 570, I do the installation and get someone to gas it up. The concern is that from what others who rent vans to transport wheelchairs is that only the front part is cool and its not really cool as as you drive you get a waves of hot air from theback and the cool air from the front. Meaning rear ac is important too.
Ive searched a bit on ac and so far, nothing on rear ac kits. I ve found roof top ac units, portable, window, ac, dc units.
As you can see, needing 40-60 amps at 12 volts or 115 volts ac and 15-20 amps will meet or exceed the charging system of the van.
A search for an ac generator to use on the fly was rather useless too. Seems they need to run at a constant speed and use the pto.
Anyway, the dc air conditions were a few grand, the ac ones were a few hundred. That kind of rules out the dc units cause the price is more than the 2gs I paid for the van.
The van has extra brackets for a second alternator and a compressor. Since the ac aftermarket kit is limited to just use in the van, I had another idea.
THe idea was to use an inverter rated large enough for a small portable or window ac unit. One of the little units with just an on/off switch. I think those draw around 600 watts. This maybe able to work off the stock charging system with a thousand or 1200 watt inverter. THen just mount the thing.
What do you think so far? This way the inverter can be used to power tools or emergency power. THe ac unit can be plugged into the line voltage if I am at a camp site or it could be brought in to use in an ac failure or power failure. Maybe less than 600 bucks for both. Yes, I am seriously considering sleeping in the van, its hugh inside.
If power is an issue, going to look for an alternator from the kidmey foundation junkyard and get a larger deep cycle battery just for the inverter. Hooking the alternator to the battery so its its own circuit. Short, monster cables too.
Ok, so how do you mount the portable or window ac system? If a window unit is used I was thinking of removing one of the rear or side windows and making a box out of wood and bolts to sandwich the unit to the opening and use lots of silicon to seal it off for water and what not. I thought about partly mounting it in the roof at an angle, but no idea if those can be mounted at an angle or not, lets say 45 degrees.
If its a portable one with an exhaust vent, maybe make a hole for the exhaust and water and mount it to the floor behind the front seat.
