ViReN
Hi,
I am looking for a suitable (if possible synchronous) Buck Converter with a low part count for a following project.
Concept: 5 mm Nichia CS B0 U Bin LED driven at 40 mA (Read: 8.24 Lumens @ 60 Lumens/Watt (**2)) powered by 2 x CR2032 (250 mAh) Cells in series in conjunction with a Buck Converter.
WHY 2 x CR2032 ?
Runtimes:
Lumen Output: Tyically the light will have a practical Lumen Rating of 8.24 Lumens performing at 60 Lumens/Watt (**2)
So one could market this light at Over 8 Lumens for Over 8 Hours from 2 x CR2032
:huh:....all these thoughts were sparked, when I saw a FREE 2 x CR2032 5mm LED Light (resistored). The light was in metal casing, small like normal small badge keychain, It comes free with 12 Duracell Cells.... Did i buy the cells for the light? ... no ... (dissaproval from Home Ministry) ... read Wife
** Foot Notes:
1) The 3.43 Vf @ 40 mA of LED was captured from JR Electronics Corporation's Spread sheets
2) The 8.24 Lumen @ 40 mA for led was captured from JR Electronics Corporation's Spread sheets
3) All the Capacities from Respective Datasheets, Used Maxwell & Energizer Datasheets.
4) The content writer has no grudges or association with ARC Flashlighs LLC or any other Manufacturer
WHY 2 x CR2032 ?
- More Power as compared with 1 AAA Cell (consider 900 mAh NiMH Cell)
- 6 x 250 = 1500 (rated power for 2 CR2032 cells)
- 1.2 x 900 = 1080 (rated power for 1 AAA NiMH Cell)
- One could argue why not use Lithium in an Arc light instead? see below for reason
- Higher Voltage at disposal as compared with AAA form factor
- 6 Volts to be specific for a 2 x CR2032
- 1.6 Volts for at max if we consider Lithium
- Power required would be ((40 mA * 3.43 Vf) * (1/0.8)) = 171.5 mW
- Current drawn from Batteries would be (171.5 mW / 6V) = 28 mA
- Consider same thing from a AAA NiMH Setup would be around 140 mA assuming the efficiency of boost converter is 80% all the time.
Runtimes:
- AAA Battery runtime will be around 900 mAh / 140 mA = 6.4 Hours, practically we see it to be around 5 hours to 50% (i.e. derated by 20% as compared to ideal situation)
- CR2032 Battery runtime will be around 250 mAh / 28 mA = 8.9 Hours, lets derate it by 20% ... 7.12 hours, its full 2 hours more than a AAA Setup
- Even in practical and worst cases, the runtime will certainly be more than 7 hours as most of the time a typical buck converter would be around 80% efficient, this is not be the case with a boost converter as the battery gets depleted, the efficiency of the converter will also suffer. If synchronous buck converter is used, efficiency would be of the order of 90% most of the time.
** Foot Notes:
