skalomax
Finally i made up my mind, i decided to get the Surefire L6 lumamax. Does anybody have any reason i shouldnt?
Whell the L6 uses the same LuxV in the same size reflector as the U2,
skalomax said:So the L6 is a better thrower than the U2? The only difference then is the versatlity of 6 power levels? I personally dont care about the versatility i just want one bright light(Surefire) that is a good thrower and has some sidespill. Well thanks for the Help and i hope to become one hell of a flashaholic
Given this, then yes, the L6 should fit your needs perfectlyskalomax said:I personally dont care about the versatility i just want one bright light(Surefire) that is a good thrower and has some sidespill.
You are well on your way. Just remember that you will spend "a lot" more on "lights" than you ever though possibleskalomax said:Well thanks for the Help and i hope to become one hell of a flashaholic
nc987 said:Not true, the L6 has a deeper reflector and a larger bezel. IMO the L6 is the best LED light I have ever come across for pure beam quality. The U2 is more versatile but I find that 99% of the time i use my U2 at full brightness anyways. However the L6 is not a tremendous thrower, it will out throw my other Lux V's (U2 & L5) but my KL3 is still my best throwing light (not including my HF HID)
Check out my beamshot comparison here of all my Surefire LED's:
https://www.candlepowerforums.com/threads/105935
Will your KL3 out throw your M3T?
