Your run-of-the-mill K2 magmod
idleprocess
decamped
So I've had this thing courtesy an anonymous individual for months now:
I finally order some parts and it starts to go together:
Emitter mounted on heatsink
The rough specs:
LED White K2 emitter (prototype), unknown bin
Host Maglite 2C, driven by NiMH cells
Driver Nextgen 1000 from the 'Shoppe
Heatsink Hotlips-C from the 'Shoppe
Opticalware Mag reflector minus cam, 52mm mineral glass from Fenix-Store.com
Power 2x Ray-O-Vac 2900mAH NiMH C cells
Runtime Approximately 90 minutes until "moon mode" with cells down to ~1.05V each. I had no interest in determining ultimate runtime.
Output No meter, no test. Better than a TWOH magmod with same optical components driven @ 500mA
Save for the K2, it was like the typical Luxeon magmod.
Tint is acceptable. It's a bit more yellow than my TWOH magmod, which seems vaguely blue by comparison.
It's visibly brighter than my 3D resistored magmod, but that's only seeing about 500mA due to ~1.1ohms of resistance in addition to contact/switch resistance. I suspect it's no more efficient than a typical Luxeon 3. Due to the prototype nature of the emitter (I obtained it before Lumileds started sampling in earnest), I expect it might not live the advertised 20-50,000 hours.
I opted to drive it at 1000mA because the dininishing-returns jump in light output per all K2 spec sheets isn't easily-perceived but the linear jump in heat output likely is.
If anyone wants more pictures, I could take some. Bear in mind that I really don't have anything to do an apples-to-apples comparison, and the emitter dates to mid/late 2005 at the earliest; likely not the best representative of the limited-production K2s now in circulation.
I know my soldering technique is sloppy and I need to use some liquid electrical tape on the emitter connections (or cheaper and more readily-available nail polish).
chesterqw
singapore,jurong
meh... can't wait for the special k2 can use hotlip to come out next month...i gonna steal your tonight...sleep tight my little light...MUAHAHAA!!!
greenLED
La Tiquicia
Nice job, Idle! :twothumbs
Pink nail polish is the official color of CPF modders.
