Protaeus
Hey guys,
I just did a runtime test on my M4 using an MN16 lamp and 2 of AW's 1600MAH protected 17670 cells.
With a current draw of 2.54 Amps, the MN16 should have a runtime of approximately 37 minutes on the 1600mah cells.
On freshly charged cells, I got a runtime of 35minutes, all with essentially the same brightness.
However, when the timer hit about 35minutes, the flashlight just completely switched off, just like what my A2 does.... Is this normal for an incandescent on rechargeables? One minute it was at full brightness, next, it was completely off...
The temperature of the torch was 44 degrees celcius, but the batteries were only slightly warm.
Im pretty happy with that - a little concerned about the sudden turning off, but happy
Also, I was wondering with the new unprotected LG 18650 cells Ive ordered, when would be a good time to charge them?
With the MN16 LA, the 2400mah LGs should run for 57 minutes - should I charge them well before that?
I dont normally use the m4 for long periods of time, maybe 10 minutes at the most - so should I charge them after every use?
Thanks guys, Ive finally moved over to rechargeables after seeing the rate the M4 swallows batteries , and Im slowly getting the hang of it
