I've read a few comments about the amount of in-line play of the tailcap on the new Inova X1s compared to the old models.
I did some measurements with a old style X1 with optics, a new-style X1 with reflector that was packaged with a holster (I'm assuming this was one of the first off of the production line), and a new-style that was packaged with a lanyard (and was bought a month after the first new-style).
The designations are:
Old-Body, Old-Cap
New0-Body, New0-Cap (this is the early production run)
New1-Body, New1-Cap
All measurements were taken with the tailcap turned out by 1 turn from fully seated. The early reflectorized model will activate even when the tailcap is backed off by over 3/4 of a turn, due to the huge play in the threads.
The threads on the body of the newer reflectorized model are cut the same as the optics model, and stop about 1.5mm from the O-ring. The early reflector has threads that come up all the way to the O-ring. The old optics model has the narrowest threads cut in the tailcap- they are extremely precise and thin, and I would assume would not thread over anything other than absolutely perfect threads on the body.
Overall, the precision of the Inova flashlights is amazing, but the mating tolerances on the early reflector model seemed to be abnormally large.
As the chart below indicates, the old model has absolutely no tailcap play, and momentary activation is entirely through the rubber cap. The new model has so much play you can activate it by pushing the solid end of the tailcap- the rubber is nearly superfluous. This makes the light feel a lot cheaper and more rattly when using it in momentary mode. The better of the new models has little enough play that it's not annoying, BUT extended signaling use of the light tends to force the tailcap to walk on the threads, and eventually it will need to be adjusted again so it doesn't start flickering the light ON when unwanted.
The old tailcap/body are clearly the best of the bunch.
I don't know the best way to keep this table in monospaced format; sorry for the kludge:
Old-Body, Old-Cap
New1-Body, New1-Cap
Code:
Body Cap Play
New0-Body, New1-Cap: .40mm
New1-Body, New0-Cap: .40mm
New0-Body, New0-Cap: .75mm
New1-Body, New1-Cap: .10mm
New0-Body, Old-Cap : .20mm
New1-Body, Old-Cap : .10mm
Old-Body, Old-Cap : .00mm
Old-Body, New0-Cap : .25mm
Old-Body, New1-Cap : .10mm
