James S said:
... but if memory serves it's in the part of the preferences that is only visible when you actually have an ipod plugged in. So plug your ipod in, let it launch, then dig through the preferences till you find how to stop it from doing that.
James is right on the money!
And
senecaripple,
[edit just noted that you are not using a PC, but your old g3 ibook. not sure if this'll help... Didn't cut text, though in hopes it may still help.]
Sorry, you'll have to connect your iPod in order to access the iPod Options.
Not sure how to bypass it on your PC w/o connecting it.
IIRC, you can connect it to another PC w/iTunes. It will prompt you with a message like - "This iPod is synchronized to another PC, would you like to synchronize to this PC?" ...something to that effect.
Maybe someone else can confirm or deny that before you try it.
Once you are able to connect without synchronizing, go to iPod options and select "Manually Manage Songs and Playlists".
Hope this helps!
