EAGTAC
Results 1 to 5 of 5
Thread: which red laser?
    Unenlightened
    Apr 2006
    California
    Default which red laser?
    I just recently purchased a red laser off ebay and it doesn't look like it can be easily modded since it only looks like it has one "DEE" resistor(?) on it. I was wondering which brand/type of RED lasers is the easiest to mod or how i would go about modding the one i have.
    Flashaholic* ACMarina's Avatar
    Sep 2004
    Brookston, IN
    Default Re: which red laser?
    You want to mod a RED laser?? The majority of reds that are modded simply have a pot to turn, but they're generally not going to get too much better than they come..
    I love my Al-PD
    *Retired* The_LED_Museum's Avatar
    Aug 2000
    Federal Way WA. USA
    All red laser pointers use a directly-injected laser diode; and many of them are already operating close to their upper maximum...there's a high likelihood of your ending up with something to feed the hungry, hungry garbage can if you attempt to modify it.
    Just my 2˘ here; individual results may vary.
    Sep 2004
    Brookston, IN
    Now THAT's a photoshop I'd like to see!! "Hungry, Hungry Garbage Cans!"
    I love my Al-PD
    Flashaholic jkaiser3000's Avatar
    Oct 2005
    Caracas, Venezuela
    DEE resistor?, you mean 330 resistor, I think . That means it's using a 33 ohm resistor to limit current reaching the diode. Red pointers are not easily moddable, all you can really do is to use one extra battery (3 instead of two, for example, if space allows it), or you could change the resistor with a lower value one, you may want to try a 220 resistor (22 ohms) or something similar. But in the end, you're very likely to end up with an expensive battery holder.
