Confident to take a plunge in the pool?
GhostReaction
Singapore
Which NON DIVE LIGHT would you be confident enough to take a plunge in the pool with you.
I was so inspired by Don McGizmo diving in the sea with his lights:eek:
So I was feeling bold :crazy: yesterday that I dived in till the base of my apartment pool which was 1.9m deep while holding my Fenix L0p. I repeat the same process with L1p as well.
After a 5 minutes dive with each lights I inspected them. The L0p seemed to performed better than the L1p. L0p internal and batt was totally dry :thumbsup: while a couple of tiny droplets seem to seep on the thread of the L1p.
I m so tempted to dive in with a HDS EDC and the ARC aaa also :p
Tried anything simmilar with your lights before?
smoking
Fine Country
my 6p+KL3 survived in the rain for about 4 to 5 hrs. the light was on my belt when i was riding back on my bike from Penang in the rain all the way down to KL. the rain along certain section of the journey was very heavy and visibility was very poor that i can only see a few car lenghts in front of me. i only realized that the light was on my belt only when i reached Malacca. checked the light and it worked as per normal. i also did not notice any condensation in the lens as well. no sign of any water seeped into the light or body. just some water residing at the tailcap gap area. the orings did a good job in keeping the water out.
Size15's
Kettering, England
I am confident to take any of the current Millennium Series SureFires I have underwater (I have done so several times). The same goes for the 6P/C2/Z2/L5/L6 etc.
This is conditional on my having checked that the o-ring seals are not damaged and sufficiently lubricated.
I would be less confident taking my EDC (currently an L2) underwater since the TailCap gets rotated a lot and the o-ring is likely a bit worn and not clean. Also, bezels such as the E2e/L2/KL4 with bezel rings if they are not sufficient sealed may or may not leak, or if you've opened them previously etc.
So I'd not worry about an E1L or E2L but I'd not be surprised in my L4 or E2e bezel leaked.
I have no experience of taking a current G2 or G2Z with LockOut TailCaps underwater. I suspect they'd be fine as long as the TailCap was not rotated.
My understanding is that double o-rings are needed/better if you want to rotate threaded parts underwater.
Furthermore, high humidity or [rapid] temperature/humidity changes may cause the water vapour already inside the flashlight to condense - for example the window to mist up.
Al
ACMarina
Brookston, IN
I'm a lifeguard, and while I generally trust my dedicated "Dive" lights to underwater duty I've yet to have any problems with any of my lights. Of course, I'm not going to try it with lights that are clearly non-watertight (ie. Maglite) but I'd have no problem or fear with any of my nicer lights..
GhostReaction
Singapore
AL, kindly confirm that its safe for me to dive with E1L to a depth of 1.9m cause I would really love to take a plunge with it.
In any case that water will seep in, does it mean goodbye to my light?
ACMarina
Brookston, IN
From what I've seen of all of my Surefire lights, it'd be okay. I believe the official word from Surefire is any of their lights would be okay to 1 ATM (35 feet or so), if you can find that in writing on Surefire's website I'd say go for it. I'd do it myself if I had one, 1.9m isn't very deep IMO..
Somy Nex
Penang, Malaysia
well, not quite the pool, but i've went into caves where we had to wade chest deep in water before, and at that time, the lights i brought along -- the Pila GL4, SF A2, Fenix L1P & Peak Caribbean -- all performed admirably while being operated & turned on and off while in around and under water. since then i've added a few more lights, and given proper maintainence, i'd trust all my SFs in a regular swimming pool, along with my GL4, HD-45, Intelli, FF3, Fenix's & Peaks... pretty much all of my lights with seals, really.
now if you are asking me if i'd take any of them as a dive light, going down to deeper... depths =P, then probably my answer would change =P the HD-45 would probalby handle that best, although i'm worried how it has no vent and am unsure if that's needed or not. i'm not a diver anyway =P
GhostReaction
Singapore
Just did a little read up on HDS and they stated it to be 66feet waterproof.
Will hit the pool again later and update this thread tomorrow.
:eek:I dont have fancy underwater camera like Don Mcgizmo but I will try to snap a few shots.
McGizmo
Maui
Fresh water and I suspect pool water with its chemicals shouldn't be too destructive to a light even if it does leak some. As I recall, Trevor once took an Arc AAA in the pool and intentionally flooded it and found it functioned fine.
I am personally much more cautious taking a light under water in the ocean. The salt water can provide unwanted electrical paths and where these paths connect to the lights electronics, you can have anodic and cathodic reactions that may severly damage the electronics. :green: I took a SF weapon light under a couple years ago and it was not sealed in its switch chamber. The salt water completed an electrical circuit (short) across the switch contacts and corroded them. I watched small cloudy bubbles exit the rear of the light and there was nothing I could do about it. I flooded the head of a PR-T a few years back and the salt water shorted across the LED leads and the electro-chemical reaction of the water in the head along with the salt, I presume, damaged and dulled the delicate reflective surface and I had to replace the reflector. The potted converter and LED continued to function properly and there was no other permanent damage to the light.
Nadar was instrumental, as I understand it, in getting the term water proof to entail a condition of an item where it could endure not only submersion but flooding as well. The Rolex and other watches changed from claims of water proof to water resistant as a result; or so I have been led to understand.
In the case of my Ti lights, I consider the Titanium hosts to be water proof but the flashlights themselves, to be water resistant if the seals are in proper functioning order. If a light were to flood, what components are likely to be damaged and if damaged, can they be repaired or replaced? Electronics? Optics? switch?
In a fresh water flood, the light will likely continue to function. In a saltwater flood, the light may or may not continue to function depending on the new electrical paths and shorts the salt water brings to bear. A conformal coating of the PCB like SF uses would probably be a real good idea if a light were intended for submersed activity. :thinking:
Size15's
Kettering, England
If you can normally safely dive to a depth of 1.9m then I don't see how taking an E1L along with you can decrease your safety. Unless you are holding it in your mouth at the time of the plunge (etc) :p
In your application of taking the flashlight underwater in a swimming pool your safety does not depend on the ability of the flashlight not to leak (and as a result stop functioning), nor does it depend on the flashlight not being damaged or out of action. Therefore I assume you are referring to the safety of the flashlight rather than your own safety.
If you consider safety to be a state of low risk and risk to be the magnitude (severity) of the possible adverse consequence(s), and the likelihood (probability) of occurrence of each consequence then as has been mentioned leaking can occur, or not, and if it does, it can cause damage, or not.
I consider the likelihood of a correctly maintained E1L leaking at a depth of 1.9m to be low. I consider the severity of the damage caused by the E1L being flooded by swimming pool water to be low. Therefore the risk is low and the E1L 'safe'.
However, if the E1L leaks it will take a long time to dry out - this must be done calmly, for example in an airing cupboard (if you have such a thing) over the course of perhaps two weeks (warm, dry, arid conditions). If you can not spare the E1L to be out of action for this length of time then I suggest you do not 'risk it'.
Bottomline: you don't know whether it can perform until it has!
Performance is a characteristic best awarded in hindsight...
Al :)
GhostReaction
Singapore
:laughing: Pardon the confusion. What I meant was the safety of the E1L:nana:
Al :)
Of cos 1.9m is not deep, its a swimming pool :ironic:
I would try to do a swim with my E1L if it arrives in Dubai.
GhostReaction
Singapore
Sorry about the picture quality. I know nothing about photography. Just to share with fellow CPF members. All pictures snapped with automatic setting.
I always prefer saltwater swimming rather than swimming pool but I will leave the ocean photography to pros like Don. :bow:
Anyway I do not have underwater camera or gadgets and the have to drive for hours over the "beach" in Dubai to reach the ocean :duh2:
The pool is 1.95m deep with no shallow ends. Brought the Fenix L0p and HDS for my swim.
Dip the L0p in first.
Next dip the HDS in just below the surface.
Once dipping test is okay, I drop the lights till the bottom of the pool
L0p:
HDS:
Both lights were left in the bottom for 5 minutes and I took each light for a lap swim.
The HDS beam underwater was impressive and all function work well while at the bottom of the pool.:thumbsup:
sween1911
Pennsylvania
Cool pics.
I would not risk my SF's at this point, but I did take a 2C/3x123 M*G into a pool. After having first electrical-taped over the switch, head/body joint and tailcap.
The thing still leaked a little bit, probably near the lens as I recall, but it was fun.
At my in-laws house, at night, we shut off the pool lights (the lights attract the BIG bugs, which attract the bats! :)), and I was diving around in total darkness . It was pretty cool.
Icebreak
by the river
I think member flash... did this, I can't remember all the lights or which one's may have leaked but I do remember all survived.
Looks like some flash...mods, Craftsman, Tektite, Mini-Mag with dat2zip sammies, a Mr. Bulk and a couple of McLuxes.
Anyway. One of my favorite photos. Thought you'd like it.
BigHonu
Honolulu, HI
I have always wondered how movement affects the pressure/depth rating on a light. Can a light held in the hand while diving at a depth 'see' a greater pressure, than that depth would normally provide, if the light were still/at rest?
nc987
While I trust my Surefires in just about any situation, I am not going to test them underwater unless of course I have to. Jumping in a pool with any of my SureFires would take alot of convincing.
I can say I have had my 6P in a downpour and it functioned perfectly.
But If i had to choose any of my lights I would probably take my E2L.
jashhash
Phillips Ranch
I submersed a shortened Mag 2D (Cut off the side switch portion) with a tailcap switch in the kitchen sink at work for 5 minutes and no water seeped through. I doubt a stock 2D light would survive though...
Dustin Liu
Banned
I took my E2D under the pacific ocean about 200 times.
It was under 20 feet
Flakey
ive taken my U2 and C3 in the bath / jaccussi with me a bunch of times. theyre alot of fun!
