AlexGT
Hi all!
I decided to start a 5600+ lumen spotlight project, details to come, but need your help on how to power this monster bulb.
How much amps does 15 volt running at 150 watt draw? I am assuming 10-11 amps. Is this correct?
If I were to use nimh cells to power this bulb, Would 14 nimh cells (Sub C or better ) equaling 16.8 volts at rest sag enough to drive this bulb at spec voltage?
Can you say 5600 lumens for 30-40 minutes....!!!
Thanks!
AlexGT
Thanks!
AlexGT
