assembling an emergency kit. i see www.foreverflashlights.com but wondering if there are other alternatives i should consider.
hivoltage said:I have not seen any shakers that were very bright. If in an emergency kit, why not got get a lithium battery light and some spare batteries in it? The batteries last for 10 years on the shelf!!!!
AlexGT said:I also asked the question when checking for a solar powered LED but decided to go with lithium instead, get a bunch of of batteries with a long running light in a pelican case and you should be OK unless you get to be at an end of the world as we know it event.
Just my .02
AlexGT
yes, but considering that i'm on a flashlight forum, i own several. however, in an emergency kit, i want a light that can be used no matter what the situation - thus a dynamo/shaker would be perfect for my little kit.fieldops said:I agree with that. Primaries last so long its definitely a good option. It is also wise to remember that in recent disasters, it was AA's and D's that went first. Lithiums were still sometimes available because there was little disaster demand for the first few days. I thought about shake lights for a long time as many disaster agencies were recommending them. I do alot of teaching on emergency kits in my local community. I found the following things:
1. They are too dim and need shaking too often
2. Anything with fast moving parts is a future broken item (then what?)
3. In an emergency you may need a light immediately. I would not like to be shaking for a time while I need a light NOW.
Empath said:Dynamo hand-cranked models generally charge a rechargeable cell, hold the power longer, have brighter leds, and doesn't affect every magnetic sensitive thing around.
a4toronto said:any recommendations on a good dynamo light? i see cheapies at costco all the time but want to get one where someone knows that it lasts a long time.
