I have a fixture which normallly takes a PAR16 50-watt halogen bulb, 120 V AC. The fixture is connected to a touch dimmer that has three settings of low, medium and high.
I put in a HR16 LED bulb, which took some searching to find. The bulb has its lowest brightness at the low setting and more brightness at the medium setting. The highest setting oddly does not affect the brightness.
The light has been on 24/7. In just a few days, I noticed the LED was growing dimmer. I have a light meter and was able to observe it for several more days. The LED is rapidly dimming, losing several foot-candlepower per hour!
The situation is reproducible on a second LED bulb from the same manufacturer and one from a different manufacturer.
The first two LED bulbs consist of several LEDs enclosed behind a glass cover. The glass cover started out clear, but in just hours began to fog up. I also noticed that it was actually hot to the touch. The fogging up effect appears to have permanently altered the glass cover.
The third bulb did not get hot at the top where the bulb is, but when I removed it, I noticed the base was very hot.
I tried the supplied halogen bulb, which works at different brightness levels for all three settings, and it does not dim at all.
What could the fixture be doing to selectively kill LEDs bulbs in what would probably be less than a week? Could the fixture somehow be oversupplying the LED with too much current?
