Yukon_Jack said:
Just how much more efficient are LED lights than top quality Incad lights? Never mind the fact that they don't break - just thinking about efficiency. Tks.
It depends upon whether you're talking about white light or color, and the wattage and voltage of the incandescent light you're comparing to.
Let's start with the area where LEDs do best-small light sources. Indicator incandescent lamps average around 2 lm/W. If you filter them to get colors then you do even worse since the filter absorbs most of the light. You end up with around 1 lm/W for amber, ~0.5 lm/W for red and green, and perhaps 0.25 lm/W for blue. LEDs do much better than that. Reds and greens are typically in the 20 to 40 lm/W range, or about 40 to 80 times better than filtered incandescent. Ambers typically give about 15 to 30 lm/W, or 15 to 30 times better. Blues average around 10 lm/W, about 40 times better. Whites fare the worst, but even commodity white LEDs these days give around 30 lm/W, or 15 times better than incandescents. The best 5mm whites are around 80 lm/W, or 40 times better. Therefore, in the area of very small amounts of light, LEDs are anywhere from 15 to 80 times more efficient.
Now let's look at low wattage, low voltage incandescents such as 6 volts and 5 watts. These are typically in the 10 lm/W area. Power LEDs these days such as Luxeons are around 30 to 50 lm/W, or 3 to 5 times better.
LEDs start to lose when you get into fairly high wattage, low voltage lamps such as 55 watts and 12 volts. These can better 30 lm/W, especially with an infrared coating. This is about in the same ballpark as power LEDs. However, power LEDs still have the advantage of much longer life. Of course, even in this area LEDs have a huge advantage if we're talking about colored light. A 55 watt, 12 volt incandescent puts out perhaps 1500 to 2000 lumens. If you filter that to get blue light you're down to 200 to 250 lumens. 12 watts worth of blue Luxeons will accomplish the same thing.
