Nite Ize LED Upgrade for Mini-Mag; failure
ks_physicist
Kansas
FYI, at about three months of intermittent use, my first Nite-Ize drop-in replacement for Mini-Mag has failed. One of the three LEDs ceased functioning for an unknown reason. It had been used with regular Rayovac AAs and has never been dropped or mishandled, so I'm certain it is a materials/assembly failure.
Returning it for a replacement...the warranty is 2 years, but it's hard to even find that on their website. Oh well...$5 almost wouldn't cover the postage to and from!
Jim
Lynx_Arc
Tulsa,OK
I guess if you were adventurous you could try to replace all 3 LEDs with some better ones.
jmw19
State College, PA
Yep, look at it as an excuse to take it apart. I don't have the figures with me, but I think that module draws around 250 mA from alkalines. Even allowing for a lower efficiency convertor, that's still likely overdriving the leds.
The leds look to be standard 5mm units - I only see 1 set of bond wires inside, so figure they're single-die. Something like the Nichia super-leds or the SMJLEDs ought to handle the extra current better, and put out more light.
From what I can see, the leds are through-hole soldered, while the other visible components are SMD. If you can get the board out of the plastic cup, replacing the leds ought to be simple.
If not, it's just $5 (and a nice excuse to try the colored NiteIze drop-ins, if you like).
Best,
Jon
Illum
Central Florida, USA
So far mine hasn't died, but if it does im ready to buy another bulb with higher qualities than the nite-ize...Luxeon... moowhahahahaha!
http://www.flashlightreviews.com/reviews/terralux_ministar2.htm
throws light comparable to my SL Jr Lux
TerraLux TLE-5 $35 + Mag [Freebie, it was a gift]
Throw: 300
Overall: 1335
Jr Lux $30
Throw: 385
Overall: 1500
Thanks Quickbeam
Source: www.flashlightreviews.com
Any one know where to find a replacement kroll switch? and whether or not it will fit on a Minim*g?
2000xlt
same thing happened to me and they sent me a new one and they gave me their ups account# so i could send them the defective one back
Yukon_Jack
Alaska
I won't be buying anymore MiniMag drop in LEDs until the new MagLite 2AA LED it out. Could be a better, more reliable light, at less than just the aftermarket drop in.
lightningbug
I think for the price, continue using it until none of the LEDs light up! How many bulbs would have bitten the dust by now?
peacefuljeffrey
Florida
Funny, I just couldn't wait for the MAGLED minis, so I bought a NiteIze drop-in for my Mini-Mag just two days ago! It works okay. (The replacement tailcap works fine, but sure does feel a little cheap.)
I don't know squat about taking these things apart, and/or replacing LEDs with better ones, etc. (much less do I know about converters, blah blah blah) so I hope this thing just keeps on working. (Of course, it's not my go-to EDC light, anyway.)
Might I mention that I have had this particular Mini-Mag for at least 15 years?! No, wait -- Holy moly, actually, I think I've had it since at least 1986, because I remember when I got it, and I think I was in 10th grade... that woulda been '86/'87!! :drool:
-Jeffrey
havand
Pa, U.S.
Atleast yours worked...bought my dad one (among other things) for Father's Day, havn't seen it light up yet. I think its a DOA. I'm a little pissed.
jnj1033
Los Angeles
I guess I just got lucky. I have 3 minimags with NiteIze dropins, and my dad has a few as well. Between the two of us, the only problem we've had was water getting in through the clickie tailcap and corroding an electrical contact surface in one of the lights. It no longer works, but the drop-in works in other minimags. Maybe I need to subject the lights to some hard use and see what happens.
I have noticed different tints with mine two are rather bluish, and one is greenish. The one I bought most recently is noticeably brighter than the other two, and I wonder if NiteIze started using more efficient LED's.
Lit Up
Exactly. And it won't be sporting 5mm's either.
Illum
jnj1033 said:
... I wonder if NiteIze started using more efficient LED's.
I don't believe nite-ize will actually use better LEDs, Nichias, respectively. cuz that will break their price point target of $5. :awman:
Personally, I found the LED modules to be a cheap, entry-level substitute for the stock minimag's bulb. A cheap alternative that puts out useable light while conserving battry power for a 10+ hour runtime. :grin2:
phaserrifle
I had an niteize Led unit, and never had a problem. unfortuneatly the tail cap switch wich came wiht it was rubbish. never realy trusted them after that.
bob4apple
Poughquag, NY
"FYI, at about three months of intermittent use, my first Nite-Ize drop-in replacement for Mini-Mag has failed. One of the three LEDs ceased functioning for an unknown reason."
The same exact thing happened to me. I don't mind, though, because it was so dim that I was happy to get rid of it.
Black Rose
Ottawa, ON, Canada
I have the 1 watt single bulb LED upgrade in several minimags and they work great.
One of the LED upgrades had a bit of a reddish hue to it. I contacted NiteIze and they sent me a new one.
x59628
Longmont, Colorado
I suggest getting their 1 watt Luxeon / IQ switch combo for $20
it's pretty bright and the switch is waterproof too!!!
it will last a long time, although after about a half year of EDC, the circuitry in the switch started to rattle. It no longer works.
Do be aware that the LED module is sorta thick, so the head of the Minimag will wobble a bit.
