AlexGT
Hi all!
After reading about a PT-20 modded by lexina to use li-ions with a 5 cell bulb, I wanted to try it out too so I ordered the light and 2 x 14500 protected li-ion, all for about $15.
The light looks very rugged, waterproof to 2000 feet!!!! and has a textured plastic reflector, If I use a higher amp bulb I fear that the reflector will melt, I did try a 6 cell Xenonstar on it and the output was impresive but decided to go for a lower bulb.
This thing is small! I like it
here are the pics
The light measures about 4 inches,
Against several known flashligths and a standard unit of measure
Pic of reflector,it is made of plastic and its textured
It has a hole to put the included lanyard,
How it fits in the hand
The beam is a bit brighter than a E2e, if The SF is rated at 60 lumens, I would say this one is about 65-70 lumens, I am using a no name 6v krypton bulb running at .65 amp so the runtime with 750ma li-ion should be about 1 hour.
12 ft. beamshot, E2e 60lumen bulb on the left PT-20 with li-ions on the right 6v /.65 ma krypton bulb, it's just a bit brighter. the beam is somewhat oval.
http://img19.imageshack.us/my.php?image=hid0017pr.jpg
Hope you liked the mini review,
AlexGT
here are the pics
AlexGT
