Illum
I bought from a friend whose hobby is to repair and mod computers half a dozen stock 12V 130-800 ma fans...sizes between 80 mm to 120mm.
As an effort to prepare for this year's hurricane season...I tested the plan using a 8 people tent [greatland] as the air circulation restriction and 4 of these dinky fans ran at 12v 1 amp using a voltage regulator, the air venting works...
Before mating the couplers to the battery...[6 fans in parallel to a fuse box, which is soldered onto washers and bolted through the hole on the terminal, using surplus speaker wire as a DC low resistance extension cord]
:huh:
I have a Exide 12V AGM Gell cell [18AH] and I was wondering:
if I connected the fans directly onto the cell, would it fry the fan and the cell?
or
would the fan draw only what it needs and thats that?
I plan to run a switch in the circuit, but not sure what type to use.
Input on this plz, ty.:candle:
:huh:
or
