TheSteve
The Surefire M6 is without a doubt my favorite incandecent light. However I think many of us cringe at the thought of 6 cr123s being done in less then 20 minutes with the wonderful MN21 bulb.
With that in mind I know I'm not the only one that was totally thrilled with the m6r battery pack when Jim announced it.
When I first saw it I decided it would be a fun project to build it myself, well its been close to a year but its finally done!
The biggest challenge was getting the darned LVR3i regulator. I contacted Willie Hunt directly but he really had no interest in selling me a small quantity(I totally understand from his point of view, but talk about frustrating!) I also let Jim know I was interested but he had none to sell at the time. Well around two weeks ago he decided to sell some spare lvrs he had so I jumped on a pair of them.
I had already built the battery portion of the pack six months ago. I used the same cells as Jim - GP1100s. I left the original shrink on them though and was quite please at how the end to end soldering turned out(some technique is required for this step!!!) I tested my soldering by snapping two soldered cells apart, if you get it right it is extremely strong and very very tough to break.
Being I've been waiting so long for the LVR3i's I've had lots of time to ponder what to use for end caps and how to integrate a charging jack.
I decided to use PC board for the end caps, using a small CNC machine I cut two round discs the right diameter. I also cut two more discs the same diameter but with center holes cut out.
For battery contacts I soldered brass washers to the center of each of the first two discs using silver solder. I took the copper off the second set of discs and they became washers to put on the ends of the pack that allowed the brass contacts to be slightly recessed - same as the contacts on the original M6 battery pack.
I then attached the LVR3i pretty much the same as Jim does, I did however add a 25 volt 470uf super low ESR capacitor to the input of the LVR - it was what I had on hand and just fit. Having a super low ESR capacitor on the input should give a little more runtime as the batteries will see a more constant load as the PWM supply switches which in turn keeps the batteries and FET cooler.
The last step was to integrate a charging jack into one of the end caps. I used a JST connector(widely used in the RC hobby industry) which was glued to the negative end cap using CA, I then used ShoeGoo to attach the rest of the connector to the batteries themselves which should give it plenty of strength. The entire connector is recessed so there is no chance of anything shorting out.
The final step was to finish the pack with black shrinkwrap, polish the contacts and build a charging cable to connect to my Schulze 330D.
I'm very pleased with the results, the pack is working great!
My hat is off to Jim who spent countless hours building m6r packs for people. At the price he sold them for he certainly had no plans to make any money. These things just do not go together quickly, and several steps, such as the soldering of the cells together requires technique and experience.
I believe Jim still has lvr's left, so maybe this will inspire someone else to also build one!
If anyone has any questions fire away!
Edit - here are some links:
Original project by js:
https://www.candlepowerforums.com/threads/64008
Forsale thread for the LVR3i's
https://www.candlepowerforums.com/threads/116544
Here are several pictures of the end result:
The pack built, lvr side:
The pack built, charging jack:
Negative end with charging jack:
Positive end:
Pack with shrinkwrap:
Pack charging:
Positive end:
Pack charging:
