those are a lot better, but the shot of the top of the circuit board, wires and shadows still obscure many of the parts and traces. have a look here
https://www.candlepowerforums.com/threads/92374
for an example of the ideal photos.
It appears that the 6-lead IC may be a I2C programmable pot. The pads (squares of exposed copper) are used to set it during manufacture. The right pad is +V, middle four are ? and leftmost is obviously batt gnd. the chip C51 is an op-amp just like in the 110's.
The following is entirely your own risk. Only you are responsible for what you do to your laser.
If you are feeling lucky, you can try this - take a 5k resistor and connect it to +V on one side. Then probe each of the 4 middle pads and see if the laser brightens any. At least two of the pads will have no response since they are the digital programming pads. If it does, that pad is the control pad for the brightness, and you can try different reistances till you reach a max. of 320 mA battery draw.
good luck.
