My SF L4 has just failed. The LED has begun flickering and looking at it, there are several "lines" in the LED that flicker, then usually only one remains lit. It glows brightly at first (sometimes), then drops down to a very dim level. At times, when I first turn it on, the entire diode lights up normally, then drops down like that after a second or two. I've also noticed that the KL4 seems to generate the same amount of heat as it would if it was working properly, even though the lumen output is probably less than one lumen. The problem doesn't appear to be in the switching mechanism or batteries either. Has anyone else had this type of problem with the KL4?
Thanks
Thanks
