batteries are notoriously low energy density. My latest lights have runtimes on the order of 10 minutes because batteries are the 'weak link'.
examples of some energy density by mass: (WH/kg)
SLA: 25
Compressed air (Co2) 34
NiCD: 50
NiMH: 60
LiON: 120
LiPO: 140
Wood: 1600-4700!
Gasoline: 11,860
So.. as you can see.. compressed air.. lower than NiCD for energy density.. but almost certainly higher in POWER density.. an added bonus.. the chilling effect of the expanding compressed gas will naturally cool the ludicrous amount of heat certainly being generated from the 100-200W lamp on the other side
lemme think about this.. i had a C02 cart around here somewhere.. 16g..
so 0.016kg x 34 WH/kg = .544WH aka 32.64 Watt-minutes.
That means 1W for 32 minutes.. about what i can get from a AAA LiON cell.. however.. having some fun.. we could probably discharge that in under 1 minute and get 32W for a minute.
change to propane at 1atm.. you get nearly 14,000WH/kg.. i can see a little butane powered lamp that runs for 6 hrs from a charge.. i will make a tester unit.. i just discovered that my thermacell has a flat aluminum plate on the outside of the burning chamber used to heat the insecticide pad.. it will mate perfectly with my peltier junction, it's almost exactly the same size. I will see what kind of voltage/power i can get and will report back.
-awr
