Maro
Hi CPFer, I want to get TranquillityBase's Q-3 Kroll switch and housing. PM to me if you have more. Used body is OK.
Thanks.
Thanks.
I want the body of QIII which can use LiIon18650 to kroll switch.Krit said:I remember that HA22 make some mod on kroll switch for QIII and it's body too.
Maro said:I want it.
18650 can be surely used by Q3.
Thanks, HA22.H22A said:Its part of a project lights that is being developed. If you are looking for more runtime, kroll switch tailcap would not allowed using 18650 battery. QIII body is small. You need to bore out the body and add body extension for it to work (I do not recommend). On the contrary, you will be able to use 17670 with body extension which is the same size as 2x r123. PM me for more details. Thanks.
Led_Experimenter might still have some of my 17670 battery tubes?Maro said:Thanks, HA22.
I look for TranquillityBase's Q-3 body.
TranquillityBase said:
TranquillityBase said:18650 is too big in diameter, It's not even possible to bore the body to fit this cell. 17670 cells will run the Q-3 a long time.
It is possible to fit a 18650 in a Q-3, but a new body would be required. :nana: :wave:slinco said:yeah, but you sig says 'anything is possible' !!!! he he
