Imalent
Results 1 to 6 of 6
Thread: On converting Maglites to LED mode
    Oct 2000
    Collegeville, PA, USA
    Default On converting Maglites to LED mode
    I was thinking about trying to modify my AAA and AA Maglites for sanity maintenance while job-hunting when I came across thelightsite on the candlepowerforums.com.
    Having more time, less money, and not much in the way of equipment (until I snag another job), can a mere mortal really and truly convert a Mag-Lite Solitaire and a double-AA Mini Maglite to LED mode without tearing out his hair?
    Be honest now. I like my Maglites and don't want to destroy them needlessly.
    Flashaholic* Klaus's Avatar
    Sep 2001
    Germany
    Default Re: On converting Maglites to LED mode
    Craig,
    do some search on the forum - almost zillion possibilities - easiest would be a tiny 12V remote controll battery in a solitaire with some resistor driving one 5mm or 3mm Nichia LED - for the AA mag use either 2 Lithium AA´s or 3N cells or 3 2/3AA NiMhs cells to driev one LED - as I already posted - this forum is so full of useful hints and how-to´s and links to forum members sites you can spent some quality time and research this in-depth without hassle. The SEARCH function of the forum works well for this and related tasks.
    Klaus
    Flashaholic* Quickbeam's Avatar
    Jun 2001
    FlashlightReviews.com
    Several solitaire mods on the Mods pages of my site - lots of other ideas as well - click the picture below to go there.
    May 2002
    Coalville, Leicestershire, England
    There are several commercial LED bulb replacements for minimag torches. I'm pretty sure that the LED museum has reviewed some.
    I have had very good luck with the Minimag 2 AA running a 5mm white LED on 2 N and 1 AAA cells. Just open up the hole in the reflector to fit the LED, shorten and thin the leads as needed and plug it right in like a normal bulb. Works like a champ!
    Jan 2001
    Zone III
    Mini-Mag, 3 N's, 5,600 Nichia White LED. Polish off the reflector and widen the hole a bit. Easy as 1-2-4.
