Finally I had the time to build a first mod using the OSRAM OSTAR LE W E3B star. My first impressions of the LED module can be found here: https://www.candlepowerforums.com/threads/115286
During testing, one of the six elements died (overheating). I'm not sure if the remaining five elements aren't permanently damaged, too.
The host is a "Golston 7W" (nice-looking 2 CR123 flashlight with a 3W luxeon star clone driven with a resistor).
I had to modify the reflector to make the OSRAM star fit at all. I wouldn't call the reflector optimized for the OSRAM star
Here are some beamshots (exp. time: 1/350s, aperture 5.6, autom. white bal.)
OSTAR mod left - Fenix L2P MillerMod 3W right
OSTAR mod left - Surefire L7 right
Notice the big donut effect ... it's because the reflector is ideal for a punctiform light source - but certainly not for a big die of about 3x2 mm... have to work on that..
The technical data:
The driver is a Shark step-up converter board from The Sandwich Shoppe, doing very well on the OSTAR with the J1 jumper connected, thus providing up to 21V.
Vf is about 15.5V, output current is 420 mA, drawing 2A from the 2x CR123 batteries. The OSTAR is underdriven @ 6.5 watts.
I think that the converter cannot feed the star with more than 420mA because the batteries cannot provide more than 2A. I should try to install more powerful batteries or change the host, maybe a Mag serves better.
Next project could be to convert my old Surefire 9N into a 15W LED monster ... we'll see.
Best regards
Luminator
The technical data:
Best regards
Luminator
