Pardon me for I am no expert on the topic... Do you get the impression that LED development is slowing?
I've read that the new K2 LEDs are capable of being brighter and more heat tolerant than Luxeon 3 LEDs. However, I also read that they require more energy to put out the same light as a conventionally driven Luxeon 3. So brighter but less efficient at lower output levels.
I also recall someone saying previously that the Luxeon 5 is basically four Luxeon 3 LEDs put together and that heat is starting to be the limiting factor for high light output. Many of the better LED lights today require built-in thermal protection to avoid permanent heat damage.
Then not that long ago there was the lumileds 100W led which (IMHO), judging from the pictures only, didn't look to any more impressive than a 100W incandescent in output. Not sure about runtime though so I'm not very confident in my findings.
After hearing about all this, are you getting roughly the same basic impression that I'm getting?
-That newer LEDs being released are not really a higher level of technology but just different variations of the same level of technology? In other words, that newer LEDs are unlikely to provide higher output at lower energy levels, in a smaller size and with a longer service life? That there has to be a trade-off in one area to improve performance in another? If yes, then what performance ceiling do you think they'll reach?
However, if you don't get this same feeling as me (if you think LEDs are still advancing as fast as ever), then how long do you think it'll be before an LED light will reach SureFire M6 levels of performance?
That means:
1. 500 lumens minimum output
2. 40 minutes of runtime on a small lithium-ion battery pack
3. LED emitter area same size as MN21 bulb or smaller (for easy beam focusing) unlike fluoroscent light sources.
4. Therefore able to offer the same throw or more, using a similarly sized reflector or smaller.
5. Cost less than US$400 to US$1000 RRP per flashlight (is not rediculously difficult to produce a decent quantity at consistant quality)
Again, lighting technology is not a forte of mine so I'd just like to hear what the general impression is. Would love it if the more technical people could chime in.
That means:
