Illum
I've used my SL PP 4AA luxeon many times since I bought it now.
Recently, I've tested it in a tub of water, works well...lights on the whole time, no flicker.
When I took it out, dried and decided to check on the batteries for water, the threads seems abnormally tight, as if been glued on...A couple twists using a towel worked...but this sound
sssssSSSSSSSSSSsss....click
Its like opening a can of sprite, or the sound of the pressurized duster make when you pull the trigger...
Is this a sign of battery venting? [The batteries are the 4 included energizer AAs BTW]
After the gas was releasted, the threads became loos again..still rigid [tight tolerances] but easily turned in and out.
any guesses?
The water was lukewarm...and the testing was done for about an hour under around less than 2 feet of water
any guesses?
