nzgunnie
I'm usung a KL-3 6P combo and was wondering what is the best type of rechargeables to use? I have found it will run on 1 x 17670 from AW, but I also assume it will run on 2x r123s, which I currently don't have.
I'm pretty sure my 17670s are 1600mah (I'm at work and can' check) and that's more than two r123s @ 700mah each, but then the r123s are putting out 7.2v - 8.4v.
Does any one have any info on which is the better option? Is it worth getting 2x protected r123s?
