xpitxbullx said:
I notice there is an upgrade for the LC for regulated output now.
Well...time to play.
Jeff
If you are talking about the Chammie driver, calling it regulated is a big stretch. As far as I know all it is is current limited plus you loose lockout capability and that very low , low. When I saw something about it's availability I was immediately interested but considering the price (IIRC 50 dollars) and the drawbacks , I cooled off pretty quick.
Having sold my U60XR several months ago , I recently took advantage of the sale on B42's and picked up 2 of them. Mine came with the new recessed switch with the longer gnurled section. A great improvement. These lights were modded with uwoj's and then those swapped for swoh's. I like the swohs best. After fooling with the B42's I broke down and purchased a U60. The first one I received really sucked nuts. Bad ano, old switch,
awful tint (should have gone straight from the reel into the garbage, actually scratch that, it shouldn't have left lumileds) but I exchanged it and got an excellent one with great ano, new switch and I don't even remember the tint since it now has a SWOH lux1. It also has been upgraded with a modified McR-20 flector and
Morelite was kind enough to mill 2 slots in the head tube for 9x1mm trits (they look
fantastic!).
Well, now I have to change my answer to this poll! While I still much prefer the weight and ergonomics of the lioncub, I now prefer my modified HDS U60 hands down. With the SWOH lux1, the U60 eats the cub for breakfast in brightness (even with a fresh off the charger 18650!) and there isn't any "Well, I sorta think the HDS is a bit brighter...", It's
obviously brighter! Also keep in mind that this isn't due to the peephole of a bezel the lioncub came with, I opened mine up. I also prefer the true power regulation of the HDS and it's flat output. It's also nice to know that while some may say I'm cooking my led with current (I don't think so as I think the difference in thermal properties is based on the itty bitty star heatsink of the lux1 versus the much larger lux3 heatsink but I'm using the beefy hds heatsink) at least I know that the thermal protection (and great thermal egress) won't fry it. With the modifications I've made and the great starting platform of the revised U60 I've got the most perfect edc I've had so far.
If everything goes smoothly with the Arc4 clips that Christoph has been cool enough to get going I will soon have an almost perfect EDC (for me at least)
