not2bright
So I picked up a 2 cell MagLed upgrade today at Wally World, from a display that was still laying on the glass counter in the Hunting/Fishing section.
Once it got sufficently dark here I tried it out in a brand new Pewter 2C Mag with fresh Ray-O-Vac Alks. Here are my observations.
Brighter overall and much more throw that either of my L1P on fresh Energizer 2500s. I would say easily twice as bright.
HDS B42XR has good output but the Mag-Led has far greater throw. It is hard to compare these two as the HDS is a good smooth beam with very useful spill, the Mag is a thrower with a little spill. Once you widen the beam on the Mag you get a donut that makes it diffucult to compare by eye.
The Mag-Led far out throws the PentagonLight L2 (running new BS 123) when the Mag is focused to a pin spot. When the hotspot is made to be the same size as the PL L2 it appears that the Mag-Led is very close in the hotspot throw with a bit less brightness in the spill that the PL L2.
And finally the closest comparison is to my Diamond DB-3W's in a pair of 3D Mags. The 3Ds were running on new R-O-V Alks. One of my DB-3W's is brighter and the Mag-Led compared favorably to it. The Mag-Led is slightly less purple in tint than the better of my two DB-3W. For all practical purposes during my test the Mag-Led in the 2C had identical output as the DB-3W in the 3D. The obvious difference is that the 2C is much smaller and lighter. That said, other than the 3D with DB-3W, the other lights I compared the 2cell Mag-Led to are much smaller in size.
The tint is good. Not my best Lux3 (the HDS is), but pretty good. For $19 it seems to be a good upgrade for the 2 cell Mags. I can't speak to the runtime, regulation, or heat dissapation.
