Gman
Whats up with the battery pack for the 8X?
The B90 is it? I see that when one pushes on the switch one is moving the entire battery up against the lamp.
The current does not flow through the torch's barrel, I can light the lamp just by pushing it onto the lamp springs outside the barrel.
Are these batteries special? How does the negative terminal get up to the top of the battery? Is there some kind of metal strip running up the side? Why does the top of the battery look like that?
Am I missing something here? Can aftermarket batteries be used to build a pack?
So many questions....
